Mini Dehumidifier
locknut
Contributor
Mini Dehumidifier
Post by locknut »
my gun safe is kept in the garage.it has silica gel packets to absorb dampness which ain't worth the package it comes in.
spotted a small amount of rust on one old gun .this ain't good...
any ideas ?
will this work ?
http://www.remington.com/products/acces ... ifier.aspx.
not a whole lot of $ in guns but they mean a lot to me... :(
Re: Mini Dehumidifier
Is that the rechargeable one? dad had MAJOR humidity issues in his 6x8' safe and he got two of those and all seems to be much better. I would not get into that safe for months and apparently he never did as he normally uses the smaller 4x4' safes for the guns he uses the most... The big safe would not just get rust but MOLD all over everything... Even if I kept WD40 on everything. This last time I cleaned everything with rubbing alcohol and then put furniture polish on the wood and oil on the metal and put it all back with those things and all seems to be good after a year.
locknut
Contributor
Post by locknut »
yes it's rechargeable. has an indicator window that changes color,they claim 30 to 60 days [depending on ambient moisture ] remove it from the safe and plug it into a wall outlet for 10 - 12 hours to regenerate some sort of water glass crystals.
found this unit in Cabela's catalog.$34.99 +S&H
question is,will the d@mn thing work or not..for 35 bucks i guess we shall see :-w
WD-40 is a definite no after it drys it tends to attract moisture or so i'm told.
I've been using Remington "REM OIL " or PB Blaster silicone spray..still got rust. :-o
Hmm, never knew that about WD (that means some of the mold/moisture from before might have been my fault from when I was cleaning them for him) Yikes.
My cabnet is in the basement. I check them about twice a year. I always wipe them off after I handle them with a silicon gun wipe and have always used WD40. No rust after 30 years with some, AND they were in 2 floods in the basement, neither reached the guns, but plenty of moisture. I am a beleiver in WD!
locknut
Contributor
Post by locknut »
here is some thoughts on using W-D on guns..
http://thefiringline.com/forums/showthread.php?t=191623
Maybe I am just lucky. But I have never had any of the issues they all talked about. I have NO rust either.
Spare Change wrote: I have NO rust either.
Your guns, maybe! But YOU....well, 'nuff said! =)) :ymdevil: :D :-*
Hey quit hijackin!
E_HILLMAN wrote:Hey quit hijackin!
Hey! Who died and made you the POst POlice? Sheesh! And iffin ya look, I did use the words gun and rust so I ain't doin' no hi-jackin'! Now, ya might git me for talkin' a little smack! :D ;;)
BTW.....don't know nuthin' 'bout that dehumidifier, don't have no rust and don't own no guns! #:-s (That last should make ya'll feel alot safer!)
Whaaa? ur the POst GObblin! tryin to get me in twubble for sumptin I didn't even do... [-(
Oh wah! Get on FB and harrass Jefferina about double postin' and leave me alone! :ymdevil: =)) :p
POst GObblin! OMG! :-o :-o [-( [-(
