Anchor Chain Price
Anchor Chain Price
WOW! this is the cheapest I have seen yet for the 1/4 G4 Anchor chain. You have to e-mail these people to get a price quote but as you see here it is well worth the e-mail.
The second cheapest I found was $3.?? something a foot.
RE: Form InquiryMonday, August 6, 2012 11:47 AM
From: "Jack" <Jack@ropeinc.com>Add sender to Contacts
To: @lakecumberlandboaters.com
We have 1/4" G-4 HT Windlass Chain for $2/ foot.
Jack Hutchinson
954-525-6575 tel.
954-525-5887 fax.
www.ropeinc.com
-----Original Message-----
Sent: Monday, August 06, 2012 11:24 AM
To: info@ropeinc.com
Subject: Form Inquiry
CoName: LakeCumberlandBoaters.com
E-mail: EHillman
Address:
City:
State: KY
Zip:
Country: USA
Phone: 859
Fax:
Need: Other
Additional comments, questions or order: Looking for price for 100' of 1/4 G4 Chain.
For example defender.com has it for $3.09 a foot and they were the cheapest I saw until these guys above.
http://www.ropeinc.com/cat-galvanized-anchor-chain.html
Re: Anchor Chain Price
question, I am guessing there is a specific coupler to connect two pieces of this chain together and still work on the windlass?
WaterWings
Post by WaterWings »
E_HILLMAN wrote:question, I am guessing there is a specific coupler to connect two pieces of this chain together and still work on the windlass?
Hey E I just use a U shaped thingy with a screw in bolt that goes across the top. True "sailors" recommend you wire it so it can not accidentally come open and there goes your anchor.
Uhhh I don't know if this applies to your windlass type operation (I strong arm it myself) but you will save yourself some scratches in the ol gel-coat if you get rubber coated chain. You only need about 10'.
BUT your windlass might require non-coated chain or you maybe looking to go with all chain...I duuno. We don't have them fancy windlasses on pontoons. :)
Good luck.
Thanks, I plan to stick with all chain. Just was hoping to add to eat I have instead of having to buy that length too.
Return to “Boater Tech Swap”
